Ana içeriğe geç
Switching iPhone 11 Display for OLED one of iPhone 11 Pro?
Hi there!
I was wondering if i could upgrade my iPhone 11 which i just bought used. I thought about switching the LCD display for the OLED one of the Pro version because I switched from an android phone with an OLED to iPhone 11 and I am really missing this feature.
Is that even possible? Or will i run into complications with that…
Thanks your for answers
Louie
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello,
No sadly this is not possible. The only replacement screens that are designed for the iPhone 11 tend to be LCD, like the original. An OLED panned from the iPhone 11 Pro will not work on an iPhone 11 straight up due to the different flex cable connectors with different positioning, and also the dimensions of the phone (the 11 has a 6.1inch display whereas the 11 Pro is smaller with a 5.8inch display) means that you wouldn’t be able to clip or secure the display at all, as the display wouldn’t fit and reach the clips (and the clips are likely different as well). So besides even the panel differences, sadly an OLED panel from an 11 Pro is very impractical and shouldn’t be used on the iPhone 11. Maybe there may be some crazy third party OLED version - but I haven’t ever seen one!
I hope this helps (:
Bu yanıt yardımcı oldu mu?
Puan 5
2 Yorum:
Thank you so much for your answer, I completely forgot that these 2 phones are different in display size. My bad.
But yeah your answer helped me out a lot, i'll try to find some third party OLEDs now :)
Even tho I think I won't be that lucky :D
Thanke anyways!
tarafından
Yes you are correct TmG. I better delete my answer.
tarafından
Yorum Ekle
What about now since the iPhone 13 is out and they are both the same screen size
Puan 0
1 Yorum:
Sadly the answer is still a definite no. The display connectors will not be the same, and the iPhone 11 has a curved screen whereas the 13 has a flat display, so there would be no way to mount a 13 screen to an 11's housing. Hope this helps! (:
tarafından
Yorum Ekle
Yanıtını ekle
Spekulatius W sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 27
Son 30 gün: 133
Her zaman: 3,784
