Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
Do you have many programs running in the backupground?
Or you may check whether the system and hardware are needing upgraded. And the hard drive space, (this is important), make sure there is enough free disk space.
Most likely your system is in CPU safe mode. This is when the systems SMC sees a defect and reduces the CPUs clocking and ramps up the fan.
Lets see if you can discover an error running the onboard diagnostics. Restart your system and press the D key did you get any error codes & messages?
Mac startup key combinations
Dan tarafından
related tutorial: https://www.minitool.com/news/how-to-spe...
Cassie Wu tarafından
