Ana içeriğe geç
Yeniden tasarlanan Pathfinder, 2013 model olarak Ekim 2012'nin sonlarında satışa sunuldu. İkinci nesil Pathfinder'da olduğu gibi, bir kez daha şasi üzerine gövde yapısından, kamyon tabanlı SUV tasarımından uzaklaştı ve unibody tasarımına geçti.
2014 Pathfinder Transmission issues
My dad’s 2014 Nissan Pathfinder recently started having what we beleive are transmission issues. as we attempt to accelerate it feels like the transmission is “slipping”, or put differently the car starts to shake a bit and it feels like power is not being applied to the wheels. we think its transmission related because when we put it in D or R it takes a moment and the car is almost like it’s in neutral before power is applied to the wheels. it takes 3-4 seconds now for the power to get applied, and then it feels like its “slipping” . i dont know if my description of the problem helps but its the best i can do. my dad said he reseached some info online and apparently this is a problem that nissan knows about but is not doing anything about to fix. he mentioned it might be a software related issue and had mentioned that some people had the problem fixed when a combination ofa valve was replaced with a software update. he said he already had the value in question replaced a while ago so im not sure what to do here. hes going to take it in but i'd love to be able to offer some helpful info as i fear this issue is going to be expensive. thanks!
Bu iyi bir soru mu?
Puan 5
1 Yorum
I have had issues with vehicles not shifting/accelerating properly when fluid levels were low. It is a very basic question I know but have you checked fluid level for the trans?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It is because of the solenoid failure. Need to replace the valve body and reprogram the transmission
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I also had this problem on my 2014 and my 2015 pathfinder it’s the Nissan cut they aren’t the best I just replaced the transmission but replacing the transmission is professional level as you have to drop the whole front subframe (engine, transmission, ect.)
Puan 1
Yorum Ekle
Yanıtını ekle
ryandasilva23 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 65
Her zaman: 3,150
