Ana içeriğe geç
26 Ekim 2018'de piyasaya sürüldü. A1984,A2105,A2106,A2108 Modelleri ile bilinir. GSM veya CDMA/eSIM , nano-SIM veya dual-SIM / 64, 128, veya 256 GB / Siyah, Beyaz, Mavi, Sarı, Mercan veya Kırmızı. ("iPhone 10 R." olarak telaffuz edilir.)
468 Soru Tümünü görüntüle
How to remove iPhone XR motherboard bottom shield?
Hello, I am trying to remove the bottom shield of an iPhone XR motherboard to replace U3300, however I have noticed that it is a lot harder to get off than other shields. By “bottom shield” I mean the shield under the battery connector. I tried 480c of heat, which is the maximum my hot air will go to, however it did not come loose. Maybe I need to heat it for longer? I am just concerned that I may damage or heat the motherboard too much. Thank you so much for your help
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
These shields are not the easiest to remove as they hold a fair bit of ground plain. I use full heat and air flow with a large or no nozzle. The shield you are talking about should come off when the hot air temp reaches around 400 degrees.
All hot air stations are different; the temperature displayed may not be accurate due to the age of the machine or its make.
You are right thinking that exposed heat might damage the motherboard. The other method you can use is to cut it off. I see a few that come in with prior repair attempts which have had the shield removed this way.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Have you checked out the teardown?
iPhone XR Teardown
Puan 1
1 Yorum:
Yes, however unfortunately it didn’t say much about how to remove the shield, although was really descriptive on the chips underneath them. Thank you for your answer though!
tarafından
Yorum Ekle
Yanıtını ekle
Colby Morris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 315
