Ana içeriğe geç
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Soru Tümünü görüntüle
Why did my Xbox 360 S turn off by itself?
Hello, my Xbox 360 Slim just turned off randomly. It didn't respond to the power button getting pressed. So I unplugged the power supply from the Xbox, after it booted up just fine but after 30 seconds it did the same thing again. (I heard a beep before it turned off.)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Sounds like it may be overheating. Have you cleaned the interior any? There may be a build up of dust causing it to overheat and shut off because it can’t cool the Xbox properly. Try opening it and seeing how much dust is in it, and if there is a lot take a brush and clean it out, and see if the issue persists. Hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
It's not overheating, I had it on for 3 minutes then while it was loading it beeped and turned off.
tarafından
Yorum Ekle
Yanıtını ekle
Kur Yente sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 157
