Vertical and one horizontal lines, ghosting image
Hello, I would like to ask question about my LG 32lb561v. I found that, backlight LED´s were burned (2 of them) and bought new line strips. Installed them and the problem is still there, as you can see on the photos.
I was looking on YouTube videos and also tried moving the video cables from Tcon board and cables to the LCD. Removed them and reconnecting all of them since I replaced the led strips. Capacitors are not swollen. Now I´m hopeless and I might think that the LCD is bad. If so there is no need to replace the panel. I´m just curious if there is something that I´m missing.
I´m looking forward for advice from you guys. Thank you.
Tomas
Update (07/24/2021)
Hello, thank you for your opinion.
Here are some photos and video, when hooked up via HDMI to PC.
When the TV is only turn on and the LG logo hover over and when it is on the upper side then everything seems normal. Also, when the logo is on bottom right you could see only small vertical line. But when the logo hits the middle spot then everything showed up.
Hope this will help you.
Bu iyi bir soru mu?
