Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
Is the problem in power ic? Dead iPhone 7
Hello, I have a normal iPhone 7,
it just turned off while i am using it
I went to the store because I expected the screen problem and he told me that the screen and battery had been changed and the problem was not solved
He told me that it might be a problem with the ic power
I just tried it and when I put the charger , the area marked in the picture is getting overheat Then the Motherboard getting medium heat
Is there anyone who has experienced like this a problem and knows the solution or cause of it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
There is shorting on the circuit that produces heat. Might be or might not be the issues of power ic. One thing remembers is that shorting on the circuit is the main culprit for that issue.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Senpai sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 403
