Ana içeriğe geç
Wi-Fi ve hücresel modelleriyle 32 veya 128 GB depolama seçeneklerine sahip, 6. nesil Apple iPad için onarım rehberleri, söküm ve sorun giderme bilgileri. Mart 2018'de piyasaya sürülmüştür. A1893 ve A1954 model numaralarıyla tanımlanır. 9,7 inç Retina ekran ve 64 bit A10 Fusion çip içerir.
Missing Pads Charge Port
Hello,
I am missing charge port pads for pins 5, 12, 14, and 20 for an iPad 6th Generation WIFI. Can some help me identify any test points on board where I can jump these to the connector?
Thanks in advance!
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
5 Yorum
you need to mark the pads in the photo or picture - the numbers of pins and lines are not marked on any of the available diagrams (let's at least set the starting point and the direction of counting - so as not to make a stupid mistake). At the same time, I confirm - such a check is possible
tarafından
I am missing the ones highlighted in light blue.
tarafından
wait...
tarafından
mmejia04 post a picture of your actual board as well. That way we can actually see the placement of the components and follow the traces as per schematic....
tarafından
I posted a new picture, the pads inside the red boxes are the ones needed. The other pads are either connected to ground or have a second connection to the same point.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
hello there,
here you've got
Resim
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
Thanks for all your help!
tarafından
I am sorry, I missed to add another pad, the one right next to the purple one.
tarafından
no problem, pict upgraded
tarafından
hi can i you help me to pin point positive and negative pin to charge the ipad 6th gen beacuse the pin was destroy im trying put jumper on it
tarafından
Hi @bryanlutuaco ,
yes, of course. unfortunately, it is difficult to post anything in the comments section :-) So start a new thread and throw a link (preferably by email - you will find it in the "about me" tab) so as not to miss it in the thicket of other messages.
tarafından
Yorum Ekle
Yanıtını ekle
mmejia04 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 73
Her zaman: 1,804
