Phone repair cleaning creates vertical lines
The screens on the amoled are really sensitive so I try my best to clean gently and have purchased one of those motorised glue remover machines.
When cleaning the final bits (after I've cleaned all that I can with the small machine) I shift to manual cleaning with acetone and those cleaning flintless tissues (the ones you can get from aliexpress etc)
I've so far destroyed 4 screens during the last bit of the cleaning process most of which create a vertical line (on my screen the touch has stopped working as well). I apply as little pressure as possible by circling and applying 99% acetone as needed
Is there anyway I can polish off the last remaining glue without applying pressure which I assume is detroying my screens as it hurts to see I've nearly completed the refurb to it to go down the pan when cleaning which should be the easiest in this type of refurb
Bu iyi bir soru mu?
