Ana içeriğe geç
Bir yürümeye başlayan çocuğun oyuncağın içine aşırı hevesle bozuk para doldurması sonucu sıkışan bir madeni parayı bulun ve çıkarın.
How can I fix it?
I found the panda version of it on the street. Its pressure plate is stuck and the panda as well.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If this is a mechanized device and a coin is jammed, the mechanism is jammed. The may require disassembling the unit to reveal its internal mechanics to examine it up close. Whether gear or levers are used, sometimes its obvious where to reverse the mechanism to unstick the stuck coin. Good luck as this may result in damage as an inexpensive piggy bank. A rocket scientist isn’t needed as most parents have to deal with real world child raising issues more important than rocket science. Parents raise future rocket scientists.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I just received the cat version of this but when i press the plate it only says “Hello” and doesnt look out nor steal the coin. How do i fix it. Its my first time using this? Should i return it?
tarafından Paylaş
Using a fresh battery? If it doesn't operate, return it for replacement or refund.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
XxNatalia_UwUxX sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 16
Son 30 gün: 49
Her zaman: 1,471
