Ana içeriğe geç
Dell Streak was released on August 13, 2010 and is exclusively available on AT&T's cellular network in the US.
Prying the LCD Screen sub assembly from the Gorilla Glass front panel
In STEP 14, it says : ""Sadly, the Streak's LCD is permanently adhered to the front panel glass. However, that LCD/glass subassembly is held in the front panel with very strong 3M adhesive, and could be removed with enough careful prying.
The LCD is bonded to the front panel glass to increase the strength of the device and sensitivity of the capacitive touch panel.
The inner face of the front panel assembly isn't all that exciting. The ear speaker and vibrator motor can be seen near its top edge. ""
Does anyone have pictures or video of this "prying" process and how can i make sure that the part i order will not need special adhesive to re-attached the "pried" part? thanks for your help, I will post pictures of my repair process of the screen once i am successful at tearing the Dell Streak down and replace the screen.
Wish me Luck !
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Don't pry it!! You'll probably end up breaking it!
Instead, get a hot air hairdryer or a heat gun and heat up the area where the adhesive is for a while. Use something plastic to see if its loose, then once it is, it'll come off pretty easy.
I had to do the same thing when my Atrix's screen shattered.
Good Luck
-Luc
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
visioneye sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,082
