Ana içeriğe geç
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Soru Tümünü görüntüle
Adhesive Strips Numbers 11-16
I try to keep adhesive strips in stock for both the 21.5” and the 27” iMacs. I noticed the the parts are now using higher numbered strips than what I am installing. Does anyone know why the number change? These are definitely for the 27” models. Are they just old stock or were they replaced by better strips?
iMac Intel 27" (2012-2019) Adhesive Strips
iMac Intel 27" Retina 5K Display Adhesive Strip Replacement
iMac Intel 27" (2012-2019) Adhesive Strips Görseli
Ürün
$19.99
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I go by the part numbers as an example the original 2012 ~ 2015 27” models have the following: 076-1419, 076-1444, 076-1416, 946-4547, 946-4548, 946-4549, 946-4551, 946-4550 & 946-4552 for their tapes
The 2016 ~ 2019 models use this set: 076-00332, 076-00330, 946-4552, 946-03774, 946-01031, 946-03775, 946-07462 & 946-07463
The real difference is the holes for the microphone. You can use either tape set as long as the holes needed for the microphone is in the correct location.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
mayer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 161
