Ana içeriğe geç
Canon EOS 60D, hareketli bir LCD ekrana sahip 18 MP bir DSLR (dijital tek lensli refleks) fotoğraf makinesidir. Kamera Ağustos 2010'da piyasaya sürülmüştür ve ön yüzünde yazan EOS 60D ibaresinden tanımlanabilir.
Canon EOS60D USB Interface Board Replacement.
My Canon EOS60D was on a tripod with USB cable in place. Tripod was knocked over and camera landed on the Port side, meaning that the USB plug hit the floor first. Since then the USB connection has not worked although all other camera functions are fine including HDMI interface and remote trigger.
Is it possible to replace the USB interface board and if so, how? I’ve looked at your guides and none go as far as accessing the USB board.
Thanks in advance
Harry Watson
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello!
Thankfully (since cameras are so pricey) they are generally repairable. However, parts can be difficult to find, especially for a camera of this age. Have you tried contacting either Canon support, or a local camera store? They will likely have parts, or be able to repair the board themselves. If they cannot, you could try to solder a new USB connector to the PCB. In the meantime (or if you determine it isn’t possible, too expensive, or too risky to try and fix the USB) try removing your SD card and read the data off of it.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
All this is good advice. Thanks for answering.
tarafından
Yorum Ekle
Yanıtını ekle
Harry Watson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 420
