Ana içeriğe geç
Repair guides, disassembly, and troubleshooting information for the first generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-010.
20 Soru Tümünü görüntüle
PS5 Dualsense Controller - Faulty 3.5mm Headphone Port
I’m running a split Headphone/USB Microphone setup (Audio Technica ATH M50X headphones, RODE NT MINI USB Microphone) and recently my headphone port has begun disconnecting on my Dualsense controller. It happens when I either rotate the jack inside the port, or if I lightly pull on the jack too (a good example of this is shown in this video as to how loose it is: ''https://www.youtube.com/watch?v=gXyNlGFt...). This is a slight annoyance considering I have to then disconnect everything and reset it all up again.
Has anyone dealt with any similar headphone port issues/replacements?
Thank you!
Jasper
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum:
I have just removed the jack from my own remote, it is surprisingly more simple than it looks.
tarafından
However it is surrounded by micro components right next to it, if you de solder the 4 pins on the edge, the other 3 on each side just push into the plastic assembly, they aren’t secured together. Just gently pull it up after you get the front 4 off and then de solder the pins. Clean it up, and you’re ready for a new one.
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
This has happen in my laptop charger port, the best bet is get a new cable and check the port by a technician.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Unfortunately I've tried multiple sets of headphones with no difference whatsoever and the headphones I'm using work fine in other devices with no issues with connectivity. I'm going to try to return the controller through the retailer I bought it through, however as shown in the video, it seems to be a consistent issue across many controllers. Will keep this post updated with any progression!
Puan 0
Yorum Ekle
I guess the headphone jack is NOT available as a spare part from Sony
Puan 0
1 Yorum:
Mobilesentrix offers them for a few bucks
tarafından
Yorum Ekle
Any update on this issue?
Puan 0
Yorum Ekle
Absolutely nothing :(
Puan 0
Yorum Ekle
I have a problem with one of my ps5 controllers where i would plugg in my headphones and the sound from my head set had sounded like static noise so i tried another controller didn’t have that issue my controller model is cfi- zct1w
Puan 0
Yorum Ekle
Yanıtını ekle
Jasper Matthews sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 62
Her zaman: 6,366
