Ana içeriğe geç
Huawei'nin Nisan 2019'da piyasaya sürdüğü amiral gemisi akıllı telefon. 6,47 inç FHD+ OLED ekran, ekran içi parmak izi sensörü, 40 MP ana kamera ve 8 MP telefoto kamera ile yeni bir kulaklık hoparlör teknolojisine sahiptir. Model numaraları VOG-L29 ve VOG-L09'dur.
No audio from bottom microphone
Hi all, I realised my P30 Pro’s bottom microphone stopped working. All apps that use this (Shazam, Google) pick up no sound from it. If I’m on a call, i have to wait between 5-10 seconds (which I think is when the top mic kicks in), then person can hear me. I have factory reset, cleared all caches but no luck so going to attempt changing the microphone/ SIM board. Has anyone done this before with success? On eb@y there are some boards that have this little silver IC in the middle of the board, and some don’t (this is on the opposites side of the SIM slot). Does anyone know what that is?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
I changed bottom board with microphone and still doesnt work
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Yes same problem I had. Changing the sim/mic board will fix problem.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
You're on the right track.
This is exactly what the p30 pro does when the bottom mic stops working.
The mic is soldered on a small pcb that has the simtray on it.
Do inspect your part before installing it because I’ve seen alot of them being very badly refurbished for resale where the IC and stucked there with glue instead of being soldered to the board. It might be hard to see without a microscope, but I just want to let you know that that is a common practice with the P30 pro sim/mic board for some reason.
I hope this helps.
Puan 1
3 Yorum:
Thank you for your response. There are 2 ICs on that board, one close to the mic port and one in the centre of the board. Do you know which one it is?
tarafından
I'm sorry, but I'm not sure I understand your question.
Just look at your board to see if the IC location matches what you are buying.
I think there maybe 2 version or so. That is because some countries uses dual sim, and some only uses single sim.
tarafından
I get shasham and g-assistant to work, by letting a voice recorder run in the background
tarafından
Yorum Ekle
Puan 1
Yorum Ekle
Yanıtını ekle
theun4given1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 35
Her zaman: 5,821
