Ana içeriğe geç
Why my pc won't turn on?
I have a problem that when i click power button nothing happens and also when i plug the charger the battery button keep flashing orange light
how to fix this problem? ty
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Thanks problem solved
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Try to reset the PC.
Disconnect the charger and then press and hold the laptop’s Power On/Off button for a full 15 seconds and then release it.
Reconnect the charger and try to turn the laptop on.
Update (08/24/2021)
@Zaki Mixer
OK
Try to reset the BIOS by disconnecting the charger and then removing the battery and then holding the Power ON button for 15 seconds and then releasing it.
Then reconnect the battery, reassemble the laptop, connect the charger and try turning it on.
Here's the maintenance and service guide for the laptop. Go to p.38 to view the necessary pre-requisite steps and then the procedure to remove the battery.
If the laptop starts OK allow it to boot all the way to the Windows desktop and then after a little while check if the battery is charging OK.
If it is allow it to fully charge before disconnecting the charger.
Also create a battery report to check the status of the battery. Compare the Design Capacity value versus the Full Charge Capacity value. With a good battery the values should be close to being the same. If the Full Charge value is <40% of the Design Capacity it may be time for a replacement battery.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
nothing happend
tarafından
Thank you very much!!!
tarafından
Yorum Ekle
Check Your Cables
Make sure any surge protector or power strip is correctly plugged into the outlet, and that the power switch is on. Plug in other devices to the power strip and confirm they are operating properly. Double-check that your PC's power supply on/off switch is on.
Regards,
Will
Puan 1
Yorum Ekle
Yanıtını ekle
Zaki Mixer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 59
Her zaman: 6,087
