Ana içeriğe geç
Third generation of the Fitbit Charge fitness tracker series.
22 Soru Tümünü görüntüle
My fitbit charge 3 is different?
As you can see in the image my fitbit charge 3 has three ribbon cables coming from the screen where the one of the teardown has only 2. My replacement screen also only has two. Can anyone explain this? What kind of connector is this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Are you sure this is an authentic fitbit? it could be a knockoff that for what ever reason needed another cable
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I am 99% sure. I also just found the box and it states that this is a special edition with fitbit pay. Maybe that the pay mechanism needed the extra cable, and it makes sence that this is mounted under the glass since the signal doesn't transfer through metal. Also the replacement screen works even without the extra cable!
tarafından
Yorum Ekle
You have a special edition Charge 3. You see them on occasion. If you have the sticker on the back of the screen, that should be removable and then you can apply it to the back of a replacement screen. Otherwise, ignore it and the payment option will just stop working. It's not a big deal if it does so unless you have a use for it.
Puan 0
Yorum Ekle
Yanıtını ekle
Niels Fennema sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 317
