Ana içeriğe geç
Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
PS5 SSD installation - replacement screw and spacer
I tried to install a new WD SN850 SSD in my PS5 last night. However when I went to remove the screw and spacer in the bay, the screw was stuck, and I just can’t remove it at all. I’m looking for a replacement screw and spacer to fit the SSD. Does anyone have any recommendations from Amazon UK or any other retailer? I’ve contacted Sony, but they haven’t got back to me at all, which isn’t a good sign. Many thanks in advance.
Bu iyi bir soru mu?
Puan 5
9 Yorum
I got the same problem too. Currently trying to find similar screw and spacer in SEA market but can't find nothing
tarafından
@Akifan Jannata I still haven't had a response from Sony Customer Support. I'd happily buy the screw and spacer if I knew what I was looking for! So frustrating!
tarafından
Hi i have the same probleme if one of you find the good dimension for the screw can you tell me
tarafından
To replace the screw that holds down the M.2 access cover, use a M3 × 16 screw.
To replace the screw that holds down the M.2 SSD drive, use a P3 × 10 screw.
To replace the spacer that supports the M.2 SSD drive, use a spacer with the dimensions φ5.5 x 3.95 mm.
tarafından
Where do they sell the spacers? I can't find it with an internet search.
tarafından
4 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
I have found a screw that has done the job for me. I got the M3-0.5 x 10mm flat head phillips screw, which fits perfectly. I didn't need a spacer either. The screw did the job on it's own. Hope that helps
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
From which UK shop?
tarafından
I ordered a new screw and spacer on Amazon. So am I good to just leave the stuck/stripped one in it’s original 110 slot?
tarafından
Yorum Ekle
This is the screw I replaced the original stock screw inside the ssd bay that holds down the ssd.
Update (06/05/2022)
This is the original screw that came with the ps5 that I damaged.
Puan 0
2 Yorum:
4-40 x 1/2 in. machine philips pan head screw fits inside the original ps5 spacer
tarafından
tarafından
Yorum Ekle
Here are images to see that the 4-40x1/2in. screw fits inside the ps5 ssd bay.
Puan 0
3 Yorum:
Bro what is the size of screw you displayed in 2nd image
tarafından
Is the screw properly fixed with ssd?? And what's the size of it?? Plz inform me Asap.
tarafından
Sorry for the late reply. The screw size is 4-40x1/2in screws.
tarafından
Yorum Ekle
https://amzn.eu/d/iJrAFeV
Puan 0
Yorum Ekle
I found this on Amazon UK, "Amazon's Choice" for ps5 ssd screw and spacer
DevineCustomz® Compatible For PS5 Mounting Solid State Disk SSD Screw Replacement Nut Console Motherboard Metal Screws
Puan 0
Yorum Ekle
Yanıtını ekle
Kevin McCubbin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 58
Son 30 gün: 200
Her zaman: 36,652
