Ana içeriğe geç
23 Ağustos 2007'de tanıtılan Nikon D300, Nikon Corporation tarafından üretilen 12,3 megapiksel yarı profesyonel DX format dijital tek lensli yansıtmalı (DSLR) fotoğraf makinesidir.
Error code F EE
After sitting unused for 4 to5 years camera does not shoot or display speed and aperture.
Code F EE flashes in upper right area of display
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
hi @bkdan
what I have found is you need to ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
Set to F22, or the highest aperture number normally marked in orange. Note the locking switch.
Resim
If the above did not resolve the problem and you still experience the error display FEE, in this case, you may need to return your equipment for service. Before doing so please also check the following.
Check that the EE servo coupling highlighted on the lens has not been broken.
Resim
Check that the F-min switch highlighted on the camera body has not been broken.
Resim
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
here is also a link to a service manual for your camera
https://www.manualslib.com/manual/857500...
tarafından Paylaş
I am a novice photographer and just bought a used Nikon D300 and was having the same issue. Changing it to the highest apperture removed the " Fee" error and allowed the shutter button to depress but it also stops the AF lens from autofocusing???
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Dan Avallone sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 69
Her zaman: 4,780
