Does replacing the battery cause fake "glitches"?
I’ve seen that replacing the battery on newer iPhones causes fake “glitches” to occur. Does this issue also happen on the iPhone 8?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Standard battery Replacements will be fine.
On the XS upwards, a new battery will give an indication on the screen that there isn't a genuine battery used, and the battery health is not available.
In that case, you need an IRP outlet to replace, or swap the small board within the battery to the replacement by spot welding, and then a small reader to reset the charge cycles.
All iPhones prior to the Xs will be fine. But as most things, you get what you pay for. The £6 “genuine” battery, avoid.
Bu yanıt yardımcı oldu mu?
My experience shows no, I replaced the battery in my 8 with an iFixit one about a year ago and haven’t had any issues with messages popping up, locking out the battery health tab, or other problems. Just be sure to get a battery from a reputable source and you should be good to go!
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 25
