Ana içeriğe geç
Compact digital camera with built-in flash with 10.0 Megapixel, 10x Optical Zoom and Image Stabilizer System. Disassembling requires the use of certain equipment.
20 Soru Tümünü görüntüle
Camera Memory card error
I have an Imagemate SanDisk 64 GB . Camera is showing memory card error and flash will not fire. How can I fix this? I have tried different card with smaller GB, to no avail.
Sincerely, LuWanna
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
well i do know this camera will not accept 64gb sd card (I have one) the most is 32gb are you using a adapter for micro sd? I had the same problem and what fixed it was using a different adapter try another sd card if you have one under 64gb
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Thank you so much! I did not know this and I will go to a 32gb. Yes I am using an adapter. Oh MY Gosh!!! I just found one in my desk :) Now my camera works, I have not been able to use my camera for well over a year now. I had a problem with batteries not working and discovered that there is also a CR1220 that goes in it. Then it was the SD card. My camera has always been an extension of my arm, I love it so much! Thank you again!
Sincerely, LuWanna
Puan 0
Yorum Ekle
Yanıtını ekle
luwannass sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 29
Her zaman: 1,702
