Ana içeriğe geç
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
22 Soru Tümünü görüntüle
Engine is making a bubbling gurgling sound like a percolator.
Bubbling gurgling sound in engine after it warms up. Drained and flushed radiator and oil. Both normal no discoloration. Engine also cracks back at full throttle. Any suggestions or thoughts?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Sounds like the radiator is not holding pressure. Try replacing the radiator cap first.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
It's holding good and snug, never had any problems with it. Doesn't leak or anything like that.
tarafından
Yorum Ekle
Richard Mallette “Engine also cracks back” could be a timing issue as well as a fuel delivery issue. The “Bubbling gurgling sound “ could be caused by air in the coolant system. You did not tell us if this all just started or if this has been going on for a while.
Puan 0
4 Yorum:
Just started yesterday
tarafından
And is 49cc single cylinder
tarafından
The coolant was kind of low when I dumped it and replaced it, but how do I purge it if air did get into the system?
tarafından
Richard Mallette what is the exact model number for your scooter
tarafından
Yorum Ekle
Yanıtını ekle
Richard Mallette sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 83
