Ana içeriğe geç
DualShock serisinin devamı olan ilk nesil Sony PlayStation 5 DualSense oyun koluna ait onarım rehberleri, söküm bilgileri ve sorun giderme bilgileri. CFI-ZCT1W model numarası ve BDM-010 anakart modeli ile tanımlanır.
Can the stick drift be solved?
This is the second controller i got stick drift on my left analog, is there a solution to this or do i have to replace it and buy another one? It’s kinda frustrating they won’t last 5 months without an issue.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 13
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The best way to prevent stick drift is to keep your controller clean. Even if it means putting it into a case every time you are done with it. Also treating the controller like it’s “glass” helps too. Don’t drop it, kick it throw it, leave it upside down with pressure on the joysticks… Etc…
If you live in a dusty state, get some compressed air and spray it out .
The pentameter is what controlled your movement axis and when it gets dirt on it it will think that’s the way to go causing drift.
I dunno I’ve never had a joystick drift on me personally. But I’ve successfully repaired over 500 for drift.
Good luck, keeep em clean!
Bu yanıt yardımcı oldu mu?
Puan 6
1 Yorum:
i agree a 100%
tarafından
Yorum Ekle
You can open it to “fix” it, but you cannot “solve” it.
Puan 4
3 Yorum:
this means I'll have to tear it down and clean it everytime, right?
tarafından
What does that mean?
tarafından
@flo73885 Means it will come back again.
tarafından
Yorum Ekle
This problem can be fixed in many ways. The methods I use involve the controller being fully disassembled and having the analog sticks exposed.
The first fix can be as simple as cleaning the analog sticks with either alcohol or some kind of electronic contact cleaner. The second option is to pry out the potentiometer that is causing the stick drift (each analog stick has two, one for up and down and the other for left and right) and clean it with a lint-free swab and some kind of cleaner, or replace the wiper if it is ever damaged. If the carbon tracks on the inside of the potentiometer is damaged, you'll need to replace them by buying replacements online, either the wipers or potentiometers alone or the entire stick module, which is what I recommend. You can buy official replacements on a site known as Mouser Electronics and search up ALPS RKJXV if the stick modules are green or C&K THB001P if the sticks are orange and black for a couple bucks each. You can look up tutorials online, but in order to do this repair, where you need to replace the potentiometers, you'll need soldering gear such as an iron, solder, flux, and a tool to remove the solder and component in order to replace the sensors. Even though I've only done this fix for DualShock 4 controllers, it should be the exact same for the Dualsense controllers since they use the same stick models. I hope this helps!
Puan 4
1 Yorum:
I put my controller back together but now I have a up/down issue along with my left/right one, should I just get a new controller or would I have to replace parts?
tarafından
Yorum Ekle
If you want a more involved solution, it's possible to replace the thumbsticks with hall effect sensor versions (search eBay / Amazon for some examples). I am currently trying this with my V4 controller and have managed to test this wired to the PC and it seems to be working really well (can't connect to PS5 yet as I have Bluetooth issues).
You do have to solder the thumbsticks onto the board and taking the old ones off is difficult unless you have a hot air rework station, but in theory the replacements should never drift as the parts have no wearing contacts. Many people have had good success. If can can fix my Bluetooth issue, I'll report back on how things go over the next few months,
Puan 0
Yorum Ekle
In the short term you could try to recalibrate the thumbsticks if the drift isn't too bad. Here is the site that you can go to for it: https://dualshock-tools.github.io/
Puan 0
Yorum Ekle
Yes the stick drift can be repaired.
I recently fixed my horizontal stick drift, but unfortunately I caused another issue.
As I was cleaning off the sensor of my right analog stick I took out the wrong sensor by mistake. I thought the right sensor was for horizontal movement and the top sensor was for vertical movement. I was so wrong.
As i put everything back together I was able to smoothly fix the horizontal movement, but really messed up my vertical movement. I tried repairing it again but the plastic holder broke off from the 3 solder points.
It was dumb to assume, but that's why we learn.
Puan 0
Yorum Ekle
Yanıtını ekle
Revolver sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 18
Son 30 gün: 85
Her zaman: 15,575
