Ana içeriğe geç
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
What does F11 mean?
Tried unplugging, and restarting.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
F11 is an indication of a communications problem.
Communications cannot be sent correctly between the machine control board and the motor control board.
Here are some possible causes:
Loose wire connection at either the machine control board or motor control board.
Machine control board failure
Motor control board failure
Door lock
Motor
Error codes can be caused by a Power Surge or other electrical anomaly, attempt to return the washer to operation by following the
Hard Reset
procedure below.
In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
Unplug or turn the circuit breaker off for 10-20 minutes.
Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
Press the Pause/Cancel/Stop button twice to clear the display.
Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Without a model number I am unable to provide you with specific information. For further assistance resubmit your question with the complete model number.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Hi, you seem to be an expert, and I thank you for sharing you experience.
What would be the Hard Reset for a Whirpool GHW9400PL1 washer?
Many thanks
Leonardo
tarafından
Yorum Ekle
Yanıtını ekle
Joyce Fraser sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 184
