Hard shell for the screen cracked
Just found out my laptop was cracked,
Please help.
Thanks
Bu iyi bir soru mu?
Please help.
Thanks
Bu iyi bir soru mu?
This was a common issue in this series. The polycarbonate case often cracks at sharp inside corners like this.
Using some 95% or better isopropyl alcohol flush out the gap of any junk using a syringe with a small needle and a few short blasts of can’ed air. Then use DAP-RapidFuse Clear All Purpose Adhesive should be enough to hold things. Make sure you have a way to press the two sides together once you get the glue in (move quickly) Don’t touch the area and hand holding is not good enough.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 55
