Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
260 Soru Tümünü görüntüle
MacBook Pro 15 late 2016 no backlight
I have this problem on my 2016 Macbook Pro but I don’t think it is related to FlexGate for two reasons:
  1. It has pretty much been a desktop its whole life, closed maybe 10 times. I have a second 2016 Macbook Pro that I use for travel.
  2. It hasn’t and currently doesn’t show any of the FlexGate symptoms such as backlight on when barely opened or stage lights.
Is there another suspect component that could cause this failure, perhaps user serviceable?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Jim Sorrels exactly what symptoms does your MBP show and what have you checked?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
There is logic within your logic board which powers the backlight LED’s within the display. While its possible that has failed. This series mostly had the FlexGate problem like the 13” model.
Sadly, Apple never fessed up about it on the 15”. It was less of a chance than the 13” models and it often happened on systems like yours! The display sitting around 45º angle as that was the high stress point on the cable.
Give this a view MacBook FlexGate Fix / Repair: What if the cable is +3mm longer?
In any case I would find a good MacBook Repair person who knows these systems at the deeper level to check if the cable is the issue or if the backlight power circuit needs repairs.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jim Sorrels sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 75
