Ana içeriğe geç
Model A2159, EMC 3301. Giriş seviyesi 13 inç MacBook Pro'nun yenilenmiş bir sürümüdür. Gümüş ve Uzay Grisi renk seçenekleriyle sunulur. Temmuz 2019'da piyasaya sürülmüştür.
Screen backlight works but no image
My father’s MacBook Pro display is not displaying any image. It happened when he opened the laptop and suddenly the picture was gone.
A couple of points.
  • The backlight is working fine and I can adjust the brightness.
  • Connecting the external monitor works.
  • I’ve opened it up twice and disconnected/reconnected the display cables (as far as I know, the right cables). I did not clean the contact pins or anything like that.
  • I’ve tried the reset PRAM/NVRAM and SMC.
  • Starting up in diagnostic mode doesn’t help as it doesn’t work with external displays.
  • I managed to reinstall a clean version of macOS by booting into recovery mode, having the screen open 5-10mm, and squeezing my little finger between the display and touch bar to navigate through the install process, not a fun time.
This happened literally a week after the warranty expired.
edit - video as requested
Bu iyi bir soru mu?
Puan 1
3 Yorum
Can you post a short vid so we can see what you are seeing this is very odd! Mevcut bir soruya görsel ekleme
Diid you select the correct system here as your issue sounds like the FlexGate issue The Design Flaw Behind MacBook Pro’s “Stage Light” Effect
What happens when you plug in an external display?
tarafından
@danj I looked up the serial, and selected the model (EMC3301) based on those results. MacBook Pro 13, 2x TB3, Touchbar, 2019.
I don't think this is the stage light issue, the entire screen lights up equally, but it's black. But I can "edit" the brightness and see the brightness changes, but there is no image, just a black screen.
Works fine on an external display.
tarafından
@danj I added the video. :)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Just wanted to be sure.
So in your case since the external display is showing an image you’ve isolated out the issue to be with the video signal path vs the backlight as you see the whole display glow grey. Basically the T-CON logic within the display assembly has failed.
Sadly the repair requires a new display assembly MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly and here’s the guide MacBook Pro 13" İki Thunderbolt Bağlantı Noktalı 2019 Ekran Düzeneği Değişimi
Replace a display compatible with a Mid 2018 to Mid 2019 model A1989 or A2159 MacBook Pro 13" with laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, and Clutch Hinges. Görseli
Ürün
$479.99
Bu yanıt yardımcı oldu mu?
Puan 1
7 Yorum:
Oh %#*@, guess this will be used as a Mac Mini from now on, the replacement screen shipped would be about $690 with VAT, hardly worth it. Thanks a lot for your super assistance/help. At least I got the keyboard replaced (and with it the battery) few days ago so at least I managed to make Apple lose a few bucks.
tarafından
@ingolfsson - Don't throw the towel in yet! If you just got your system repaired (keyboard) under the Apple extended warranty, I think you can get your system fixed under the repair warranty! FREE REPAIR which is 90 days of the systems service
You have a short window so get to the Store ASAP to get it fixed under the repair warranty!
tarafından
Wait, so even though it's out of warranty because I had the keyboard replaced the screen could be valid for a free repair as well? The repair shop (Authorized Service Provider) knew the screen wasn't working properly when I had them replace the keyboard (+battery and top cover) - they even gave me a quote for the screen repair ($1200 ish) which I declined, but you think that I still might have them replace the screen under warranty because the battery was replaced?
Also thanks a lot for all the help and for taking the time to respond.
tarafından
@ingolfsson - Ah! So you showed up with a dead display for the keyboard repair, then that changes things! You already acknowledged the defect.
No go on getting a free repair here sorry ;-{
If you had shown up with nothing but a bad keyboard then that would have been on them for breaking your display.
tarafından
Yeah, I figured. They had to test the keyboard when I handed it over so I had to explain that the display wasn't showing an image. But thanks for everything, it shall be used as a Mac Mini from now on. :)
I wonder if I remove the display, will it boot and use the external display as the main display.. Right now using recovery mode is a huge hassle since it doesn't display anything on the external monitor, so installing macOS is a painful process.
Edit. I meant disconnect the display from the MB since I still need the wifi to work. :)
tarafından
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
ingolfsson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 57
Son 30 gün: 209
Her zaman: 15,769
