Dewalt dcb606 Doesn’t charge at all
When I plug it in, it will flash once and then the light will fade out and won’t do anything. Second battery to do this. I have a second dcb606 that does the same thing.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@mathewshap81261 not sure why this just popped up in Answer but here it is. This is just for completion sake. Yor charger may not recognize the batteries due to the battery charge controller IC not reporting it. This can be if the battery is discharged below the IC's set threshold. Sometimes, you can "wake" the battery up by connecting a full battery to the empty ones for a few seconds. Connect B+ to B+ and B- to B- DO NOT KEEP IT ON FOR LONGER THAN A FEW SECONDS. This should reset the EEPROM in the battery.
Of course, there is always the possibilities of failed cells and just being a bad battery. There are ways to rebuild them but it's a bit more complex :-)
Bu yanıt yardımcı oldu mu?
Is your second battery fully charged and brand new? It might be that the battery is so low that the charger can't recognize it.
It's dead cell usually 3 I found on bottom row but to tear it apart not easy
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 68
Her zaman: 1,429
