Ana içeriğe geç
32 veya 128 GB depolama seçeneğiyle sunulan, 4G LTE özellikli 5. nesil Apple iPad için onarım rehberleri, parçalarına ayırma ve sorun giderme bilgileri. Mart 2017'de piyasaya sürülmüştür. A1823 model numarasıyla tanımlanır. 9,7 inç Retina ekrana ve 64 bit A9 işlemciye sahiptir.
Home button not working
Hi,
I purchased an iPad described as “badly cracked screen but everything else working perfectly”
When I received it I discovered the home button wasn’t working. I wasn’t too worried as I noted a hole in screen above home button ribbon cable, and I could just order a screen with a button.
After changing screen I have found it is still not working!
Q1. Could I test it with a home button from an iPad 7? Or would that cause damage/not work anyway? (I ask because I have one that I could try)
Q2. If it's not the home button, how hard/easy would it likely by to have problem diagnosed and fixed? The connector looks fine to my eye.
Any advise on course of action would be appreciated
Thanks
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You might have ordered a digitizer with a home button for an iPad Air pre-installed. These are common because the Air does not have touch ID. You have to order a home button specifically for an iPad 5.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thanks for that, I think you are right.
I ordered an"iPad 5 digitiser with home button flex" but pretty sure button is for Air.
Annoying, but a relief!
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Chris Reader sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 385
