Ana içeriğe geç
iMac Pro, Apple'ın bugüne kadarki en güçlü iMac modelidir. 3,2 GHz 8 çekirdekli, 3,0 GHz 10 çekirdekli, 2,5 GHz 14 çekirdekli veya 2,3 GHz 18 çekirdekli Xeon W işlemci seçenekleriyle sunulur. EMC 3144 / A1862 (Kimlik iMacPro1,1)
I want to upgrade RAM
I have an iMac Pro 2017 8 core 3,2 with 32 gig RAM (EMC 3144). Can I upgrade the RAM on this model?
there is no reference to EMC 3144 on the ifixit site
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
We don’t have a guide to upgrade the RAM for this system. Apple made the design much harder than the regular 27” iMac’s which have a RAM access door. Here the system needs a complete teardown lifting the logic board fully out to gain access to the four SO-DIMM slots.
Unless you’ve done a bit of work on the newer 2013 ‘Thin Series’ onwards iMac’s so you are comfortable in taking the display off and have taken out the logic boards I would recommend you find someone who has, as this is an expensive system to get repaired if you make any errors.
OK I’m going for it!
First you need special PC4-21300 32 GB ECC Registered RAM iMac Pro Memory Maxxer RAM Upgrade Kit
Follow this guide to take the display off iMac Intel 27" Retina 5K Ekran Değişimi the cable connections are slightly different than what this guide shows. Here’s a better image of the connections.
Resim
Review this iMac Pro Teardown for guidance as the steps of removing the logic board as that’s all there is. Step 7 is as far as you need to get to.
Install 128 GB of RAM in your EMC 3144 iMac Pro. Compatible with 3.2, 3.0, 2.5, or 2.3 GHz Late 2017 iMac Pros. Görseli
Ürün
$731.99
iMac Intel 27" Retina 5K Display Ekran Görseli
Kılavuz
Zorluk:
Orta
30 - 45 minutes
iMac Pro Görseli
Kılavuz
iMac Pro Teardown
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
Yes to all of this. And yes to this is not a repair for folks who are inexperienced. It takes A LOT of doing, since the whole logic board needs to be removed, the DIMM slots are on the back of the board. But it's definitely plausible.
This is a procedure Apple will also do for you, but I would totally understand not wanting to take it to them since RAM will absolutely be pricey. And if it is a repair you can do yourself then why bother.
tarafından
Yorum Ekle
Yanıtını ekle
Andrew Wessels sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 1,717
