Ana içeriğe geç
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Is it possible to recover my bootcamp and reinstall OSX?
Macbook Pro 15” Late 2013 2.3Ghz. It was stupid of me to take this so lightly. I had a small partition that I had made in my boot camp windows 8.1 that I wasn’t using. So I used mini partition tool to merge that and the bootcamp drive, it asked me to restart and I did. Well it completed the process and rebooted, but it doesn’t load up. The initial music plays and then it plays a a very tiny clip of that music and stays stuck on a black screen with no errors; sort of like when a game freezes and the music clips and loops.
So then I forced a reboot with the powerbutton. Still the same. Then I held down option after booting. To my surprised it only showed Recovery and Bootcamp options. If I select bootcamp, the above explained situation happens.
I selected recovery and went into disk utility. It only showed disk02, recovery HD, bootcamp and under disk 1 OSX Base System. I’ll attach an image. The 02 and Bootcamp are greyed out. I cannot mount them. I cannot erase them.
At one point when I clicked verify on 02, it gave an error “Unable to repair while live”. I felt positive then went to try and do a reinstall of OS X, but can’t select that drive because it’s in MS-DOS(FAT32) format. So I went back and now the drive is greyed out again. Verifying and repairing gives errors, and can’t be mounted.
I tried fsck fy in singleuser mode but it gave a command not found error.
When I click the 02 and bootcamp drives, they only show capacity now, and “-“ all other info.
What can I do to resolve this? Is there anyway the files are still there? I was hoping maybe I could reinstall OSX then repair the Bootcamp drive some how. What are my options?
Edit: I did an NVRAM reset and now it shows disk0s2 as Mac OS Extended Format.
Edit: I tried to do a repair after and it gave the error “Disk utility can’t repair this disk...disk, and restore your backed-up files”. Not sure why it said disk twice.
Update: 09/11/2021
Alright so none of my attempts at erasing or unmounting disk0s2 worked. I have been attempting to reinstall macOS X on it and it was getting stuck at a certain point.
I created a bootdrive with high sierra as I got recommended to do so on another forum since OS X Mavericks is really old even though that was what was last installed on it. I tried booting through it and force unmounting and erasing disk0s2 (diskutil eraseVolume and diskutil unmountDiskforce JHFS+) before install but in both cases it failed at the unmounting part. When I run verify/repair it goes through without issues the last time I ran. I am just unable to unmount. I tried the lsof |grep disk0 command to see if there are any process running, but it doesn’t give me a response, nothing happens; no errors or a response, but it does run the command because if I try to quit terminal it tells me so. Maybe I am doing something wrong.
So after that didn’t work, I said screw it and just tried to install sierra using the bootdrive and launched it. It starts installing and gets stuck at 2 minutes remaining, around 85% of the way through. I had to force restart due to that a few times; even if I let it continue it seems to get stuck at 18minutes remaining, around 5% of the way through. Some files are getting written because I see the capacity of the drive being reduced when I relaunch into Utility menu. However it doesn’t necessarily increase each time that I have noticed, only when attempting both this and the below method did the Used amount increase from what I noticed.
When I go through internet recovery, it downloads mavericks 10.9 for me and attempts to install. It downloads and goes through the installation. Then it finishes, goes into a grey screen(pic below)with a loading circle for quite some time, and restarts but ends up hanging when it does where it’s stuck on a semi white screen with a loading circle showing it’s loading. I am sleep deprived so fell asleep while waiting the last time and even after 4 hours or so it was still stuck there. The fileis getting downloaded as there is a change in drive capacity. As of now it’s used around 11 GB where as it was pretty much empty before any of these operations.
(grey screen)
So since even that didn’t work, I thought maybe I could reformat the drive I was using for booting then try installing macOS X on that to see if I can get into it and recover my files(at least some of the important ones). So I got into internet recovery and did that. Just like above it goes into the grey screen with loading icon, then restarts and hangs on a white screen with a loading circle.
At the moment I restarted and ran the OS C installer for Mavericks by booting into the Options menu. The install completed in about 20 minutes and now it’s stuck on the grey screen before restarting. I am going to let it be longer and see if it restarts; if not I’ll have to force it again.
If that happens, I’ll post a diskutil list because there are multiple disks for some reason and some and really tiny. My biggest issue here is trying to recover bootcamp files. Could the unmounting failure be because my Recovery HD is in the same disk as the disk0s2? Or is this some kind of a permission issue?
Update:
Alright so I had to force restart, and gladly it showed the external as MacOS X. I launched it and it boot into MacOS X Maverick. I am currently recovering files in boot camp using disk drill. However I am still unable to erase my disk0s2. It still gives the unable to dismount error. How can I circumvent this?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I finally got the disk to mount by using the terminal from the MacOS X and doing a zerodisk erase on the bootcamp, then also on the disk0s2 which failed but not due to dismount failure. Then I went into command + Recovery, disk02 had dismounted. Then I dismounted Recovery HD, and initiated disk erase from Disk Utility. Booted up from the bootable USB to High Sierra I had made and ran the installation. Everything installed perfectly. Now all is well :)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Ouch!
Sorry, this is a deep onion problem which really will need reformatting and rebuilding to fix. Hopefully you have a backup of your stuff.
Your other option which you might want to look at is to get a bigger drive, leaving this drive alone for now and then using a special case and a data recover app try to recover your stuff.
Update (11/08/2021)
Using a Mac download from here the Sierra installer How to get old versions of macOS
The drive you are using needs to be formatted with GUID and a journaled file system to work properly. So you will likely need to reformat it using your Mac (or someones else’s).
With that done copy over the installer and then launch it to unpack it and drag out if needed so the it can be run on its own, exit if you launch it.
Now we need to convert it into a self booting installer following this guide How to create a bootable macOS Sierra installer drive
Once done reboot your system with this drive connected. It should latch on its own if not use the Boot Manager, restarting your system again and this time press the Option (⌥) key and select your installer drive using the arrow keys and enter.
Reference: Mac startup key combinations
Now delete the partitions in your internal drive, reformat the partition and then install the OS to it.
Puan 2
23 Yorum:
I don’t mind reformatting and rebuilding. Would need help with that as well, but just wanted to try out every option possible before I do that.
If I use an external hdd would it be possible to install the OS without having to format it? I can’t really afford to get another hard drive right now, definitely not an SSD. I am guessing the answer is no but for some reason wanted to ask anyway hahah
tarafından
@hellpal - OK, do you have a 32GB thumb drive which you can prep up as a bootable OS installer? that would be the cheapest way and then using it to boot up your system to gain access to the thumb drives Disk Utility to delete the partitions on the internal drive and reformat it and lastly install a fresh OS on it.
Can you tell me what you are currently running for a OS so I can give you the you'll need and if you need to use another system to set things up if you can't get your system running to prep the thumb drive.
tarafından
@danj Don’t have a USB, but I could back up the files in my external hard drive and use that. Will that do?
I haven’t really used the OS X in years, when I go into Reinstall it shows Mavericks
tarafından
@hellpal - I would search out for a 32GB thumb drive as it would make things much easier! Setting up your external drive would mean loosing what's on it so I wouldn't do that.
OK Mavericks is way too old! Lets get to Sierra as that can still support your older OS-X/macOS apps you may still kicking around. As far as Windows what version would you you be running? Thats assuming you are still aiming for BootCamp
tarafından
@danj it’s midnight over here and the USBs I have aren’t sufficient. It’s alright I can back up this to another laptop and use it.
Hahaha yeah I didn’t use it. I believe it was Mavericks that was last running and I never updated. So any apps there would be outdated as well. I pretty much didn’t isr OS X. So unless apps not being supported is not the only issue, I don’t mind installing Mavericks so I can save some space on the hard as well as save my internet bandwidth. Internet isn’t unlimited here sadly
tarafından
18 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
VDJ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,132
