Ana içeriğe geç
A1418 | EMC 2889 | 2015 Sonu | 1,6 GHz çift çekirdekli Intel Core i5 veya 2,8 GHz dört çekirdekli Intel Core i5. 13 Ekim 2015'te piyasaya sürüldü.
What does blinking LEDs 1 and 2 mean?
iMac 21.5” does not power up, no chime is heard. I know that LED codes are: LED 1 on= trickle voltage from power supply is detected by logicboard. LED2 on= logic board has detected proper power from the power supply when the computer is turned on.
The problem is BOTH LEDs 1 and 2 are BLINKING (not ON continuously) when I connect the AC power cable to the mains wall socket. What problem does this point to?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
4 Yorum:
Can you offer some additional details on what preceded things here.
tarafından
Nothing unusual happened prior to. Thing just suddenly won't turn on.
tarafından
Where is the light coming from?
tarafından
Light comes from the vertically arranged LED array on the logicboard.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
What does the other LED’s telling you?
Resim
Did you try reseating the RAM? Did you replace the RAM you might have a bad SO-DIMM.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
The RAM is permanently soldered to the logicboard in this model, and cannot be replaced.
tarafından
Dan, when I press the power button, the 2 other LEDs remain unlit, #1 and #2 LEDs turn off. When I release the power button, LEDs #3 and 4 remain off and #1 and #2 start to blink again.
tarafından
@Bernie - Sorry your right! One of the few iMacs with soldered RAM.
I think your logic board is blown then.
tarafından
Yorum Ekle
Yanıtını ekle
Bernie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 529
