Is the screen or the flex?
I will change the screen of my Apple Watch, I charge it to be sure the battery is still working, but the screen doesn’t show anything, is just black but the Apple Watch still working, so i want to be sure is the screen or the ribbon flex in the main board, what i can do? I dont want to waste $50 :/
EDIT: The Watch was funcionally before one day I put my hand into my pocked and the belt ripped off in a bad way the Watch (i dont remember well if i pull it off hard and landed in the ground or just pull it off from my waist and just put it in my bed) because it was making a bad noise and scare me a lot.
Bu iyi bir soru mu?
Was the watch opened? Why do you think the display is bad? Are you able to see the watch via your iPhone?
Dan tarafından
@danj My Apple Watch was linked to my old iPhone 7, so, i cant see the Watch via any other iPhone, the display doesn’t work at all. (And yes, is was opened, in fact, is still opened because the screen was totally crashed so it doesn’t work and doesn’t have a lot of parts of the crystal)
Luis Rosales tarafından
if the cables dont look ripped /kinked/creased they are (probably) fine. sounds like a mangled display. the cables couldve sustained damage due to spontaneous current draw from screen when cracked. severly cracked screens experience shorts inside the oled panel
Brian Delatte tarafından
