Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
260 Soru Tümünü görüntüle
Why is my replaced battery only charging once it has been drained?
I replaced my battery a second time after the first stopped charging at all. The second battery only seems to charge once it has run out completely and not while plugged in and being used - I have attached a coconutBattery screenshot. Any ideas?
I have updated to Monterey to see if it helps. Here is the current info:
Bu iyi bir soru mu?
Puan 0
1 Yorum
Thank you. I guess there’s not much I can do about that. ☹️
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You have a threshold issue within the charging control logic. Sadly that’s part of the logic board that needs service.
You might want to try the other side ports a try to see if thats better as your system has two Intel JHL6540 Thunderbolt 3 controllers (light Blue marked chips)
Otherwise its within the SMC logic which you could have hit while disconnecting the battery (light Green marked chip)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jonathan B sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 53
