Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
Power (sleep/wake) button not working
Hello all,
I bought a used iPhone7 and have found that the sleep/wake button does not work. This means I can’t power the phone on or off with the button either.
I replaced the power flex cable with spare flexes from two other phones and it still does not work. I took apart the power button assembly and made sure it was clean. The button makes a nice click when you press it and everything seems good to go.
I’m doubtful that all 3 power flexes were bad. Could this be a problem with the logic board?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You can test the board with tweezers. Place one point of the tweezers on the pin 13 and the other point on the ground 19 or 20 leave on there for three seconds. If it doesn’t start booting you will need to check the BUTTON_POWER_KEY_CONN_L circuit and make sure it is getting 1V8 to it.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Chris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 135
