Ana içeriğe geç
The HP Envy 7640 is an all-in-one inkjet printer with a built-in scanner and faxing capabilities. It can be connected to your devices via Internet, WiFi, or a USB cable.
Load noise while printing and print is barely visible
While my printer is printing we hear a very load noise almost as if it is struggling or grinding. Also, when a page is printed, it's not clear seems as if it doesn't print properly and the ink is almost full so should print clearly. Thank you for any help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Those are two different issues. First the low ink issue. The print heads can get clogged and there is a clean printhead function. repeat several times until you get good ink.
second one is likely a plastic gear that you will need to find and replace.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Krystal Torres sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 201
