Ana içeriğe geç
Tablet benzeri bir form faktörüne dönüşmesini sağlayan 360 derece menteşeli, 13 inçlik bir "2'si 1 arada" dizüstü bilgisayar.
Battery compatible with my device?
Hello, I wanted to confirm that the Dell WDX0R battery listed for the Inspiron 13-5368 would be compatible with the Inspiron 13-5378? The battery is completely dead, so it can be only used on AC power and I wanted to replace it.
Dell WDX0R Battery
Thanks!
Replace a dead or malfunctioning battery for laptops using a Dell model WDX0R battery. Görseli
Ürün
Dell WDX0R Battery
$69.99
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Dell WDX0R Battery
according to what I can find no they are slightly different but here is the correct battery
Ürün
Dell WDX0R Battery
$69.99
Bu yanıt yardımcı oldu mu?
Puan 1
13 Yorum:
Hi @stressmaster ,
In the link you posted it shows that the battery, model # WDXOR, is compatible with a Dell 13-5368 and a 13-5378.
It's the same battery model number as shown in the image for the ifixit one, so it should be the same or am I missing something?
If necessary the OP can check using this link to check for compatibility using the laptop's service tag. It is also a WDXOR battery
Cheers
tarafından
@jayeff you will notice that that model doesn't show up in the like. I believe it is a Wh thing or a screw placement.
tarafından
@stressmaster The wh just means it will run longer, especially if this battery has a higher Wh rating then the original. The voltage has to match or be in the supported range, but you can upgrade the Wh on a laptop battery.
tarafından
@stressmaster
It can't be a screw placement otherwise what's the point of model numbers?
If they had different model numbers, albeit only a suffix to the model number, then fair enough, that would denote that they're different in some way.
This link also shows that a WDXOR battery is compatible with both models that the OP asked about.
tarafından
@jayeff looks like you're right and it's compatible. Maybe ifix needs to update listing
tarafından
8 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Auchhior sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 503
