Ana içeriğe geç
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Soru Tümünü görüntüle
How to open the magsafe adapter brick?
Hello, i know its a hard work and it will be a lot of cosmetic damage to the brick of the magsafe, but how can i easily split the case of the magsafe, to solder the wires again?, also i'd like to do minimal cosmetic damage to the charger, thank you :)
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
These things were not built to be opened as there are really no serviceable parts. I've used a Dremel type tool with a cutting disk to get into them with minimal damage. I cut along the seams.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Yanıtını ekle
Dario sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 1,509
