Ana içeriğe geç
My Xbox has Heat Problems
Hi,
my xbox has a problem with overheat. When i play on this console it will after 10 minutes overheat and the console turn automatically off. When I restart come the advice that the console overheat Also is the console very loud. My question is how i can fix this problem.
Thanks for fast questions
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Archer,
The first thing I would do is clean the machine. Open the case and dig in to the internals using this guide and blast everything with compressed air. Once you are sure that everything is nice and clean, re-assemble and be sure that where-ever you place your xbox, it has sufficient ventilation (IE it's not in some small cabinet or on carpet). You may also consider some sort of external cooling fan and/or setting the xbox so it's standing with the CD drive vertical to give more cooling surface area.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thanks for the fast answer but the problem is still there. I Had the console cleaned. I used external Fans. Is there an other solution?
tarafından
leave the cover off, plug in, turn on, watch the fans.. they might need replacing, or you may need to replace the thermal paste a la RROD repair before you get the RROD.
tarafından
Yorum Ekle
Yanıtını ekle
Archer564 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 654
