Ana içeriğe geç
2010 yılında piyasaya sürülen Flip Mino HD, 4 GB kapasiteye ve bir saatlik çekim süresine sahip, cep boyutunda bir video kameradır.
Replacement for Flip out USB
Hi there, my Flip Mino HD has a damaged ribbon cable for the USB on the camcorder, I can no longer charge it without the usb. If I can fix the ribbon cable how would I do that, If I need to buy the part where can I buy it from? All help would be appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You need to find out how many wires are in it than order a roll of flat ribbon cable from Amazon.
https://www.amazon.com/s?k=flat+ribbon+c...
Bu yanıt yardımcı oldu mu?
Puan 1
9 Yorum:
I can’t find the right one and the cable is physically attached to the flip out usb of the camcorder.
tarafından Paylaş
@TechVid How many wires is in the ribbon?
tarafından Paylaş
Alao a picture of that connection will help but it's probably just soldered. The wire can be split apart and soldered into place.
tarafından Paylaş
It is a flat flex cable and I am not sure how to do micro soldering nor do I own a soldering iron
tarafından Paylaş
Is it true that I can cut the rest of the cable, scratch a little bit of the torn side of the cable until the connectors are showing on both sides of the torn cable and tape them together with both sides touching? Also thanks for not telling me to get a new camcorder, the camcorder is special to me.
tarafından Paylaş
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
TechVid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 498
