Ana içeriğe geç
Eylül 2009'da piyasaya sürülen Samsung GT-E2120, dahili FM radyo anteni ve Bluetooth kablosuz bağlantı özelliğine sahiptir.
Why it is not continue starting
it start for a while the phone models appear and then turn off again..
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The model of my phone is GT-E2120 as mentioned here,my phone is not getting switched on,i don't know why. It was initially getting switched off for every five minutes but now it has got switched off completely and I have tried switching it on but it's not getting switched on and i have also tried plugging in the charger but there is no difference,it remains to be switched off.Am not understanding what the problem is,how do i fix this?please help..
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
So I know how to do this first connected to a PC and restore some things or if it doesn't work try going to the repair shop so they can repair your phone and work back to normal if it doesn't work still call Samsung
tarafından Paylaş
I usually have the same phone but it works properly :)
tarafından Paylaş
Yorum Ekle
This sounds like a case of dead battery. Plug your phone into the charger and try to turn it on. Does it? If it does, you need a new battery. If that doesn't work, try doing a hard reset. You will lose all of your saved data, but it may recover the phone.
Puan 0
Yorum Ekle
it's a common problem. you have to update firmware
http://www.symbianize.com/showthread.php...
Puan 0
Yorum Ekle
Yanıtını ekle
nelson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 4,274
