Ana içeriğe geç
Power/Sleep and Home Button Unresponsive
I have a iPod Touch 4g which has a cracked screen. I replaced it, and still didn't put it back. I attached the two wires from the screen to the iPod, and now the Power Button and touch screen are not working. I plug in my charger, and it goes to the password screen, and I can't slide it.
How can I fix this?
EDIT: The volume button also don't work :/
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Assuming that everything worked well before, the #1 culprit for malfunctioning electronics after dis-assembly tends to be dirty or poorly seated connectors. Clean everything well with a high-content rubbing alcohol and make sure the connectors are seated fully. If that all checks out, closely inspect each of the connectors and see if a pin was damaged. Good luck and let us know what you find!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I tried this, and now the display doesn't light up anymore when I plug the charger in :(
tarafından
Yorum Ekle
It is most definitely a damaged on/off, volume flex cable. There is a post elsewhere on this site.
Puan 0
Yorum Ekle
Yanıtını ekle
Cytonic sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,009
