Ana içeriğe geç
gold spring for Homebutton connection
Hi,
I lost the little gold spring (in the middle) for the Homebutton connection.
Now I want to fix a self made spring instead of.
Is this little spring fixed with a screw or solded?
Do you have experiences with replacing this spring?
Thank you very much,
martin
Bu iyi bir soru mu?
Puan -1
1 Yorum
Hi,
I fixed the little spring successful, but suddenly the iPod did turn on again. When I opened the iPod, the little spring was broken and lying on the logic board. Do you think the logic board is gone now, because the spring touched the little transistors, or will it work again?
It still doesn't turn on!
How can I find out if the logic board is broken?
Thank you very much.
martin
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The spring is soldered. I replaced one and had to use a needle nose plier to hold it while I soldered it. Put a little solder on spring and a little on board and applying it will be a lot easier.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thank you very much, I am gonna try it.
tarafından
Yorum Ekle
if you no good at soldering..you can buy some
solder glue that will just stick to the connection
but its slightly expensive but will last you years.
Puan 0
Yorum Ekle
Yanıtını ekle
martinkreis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,349
