Ana içeriğe geç
The Oneplus Nord is a mid-range phone and was released in 2020. It features a 6.44" 90 Hz Fluid AMOLED, runs on a Snapdragon 765G with 8/12 GB RAM, 128/256 GB of storage, and offers four rear cameras and two front-facing cameras.
26 Soru Tümünü görüntüle
Does the Glass Back Cover Adhesive need to be replaced on reassembly?
Hi there,
I was about to take my OnePlus Nord back cover off to test something with my vibration motor and realised that I might have to replace the adhesive when putting things back together. I am new to taking phones apart that use glue, so I wasn’t sure how this would work, especially since the Nord doesn’t require a heatgun to remove the back.
Do I need to replace the original adhesive before putting the rear cover back on, or does it fit back together without doing that using other connectors or possibly the original adhesive?
thanks,
Yannick
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Would recommend getting adhesive for water-resistant but you should just be able to slap it back on if you really need to
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hi @consistent ,
Thank you for your answer. I do actually need it to be water resistant, because I use my phone a lot on my motorbike.
Would you say removing the adhesive with acetone and then using one of these to put it back on would work?
Tesa 61395 Tape
Polyimide Tape
Do you know what type of adhesive or glue would be best and also keep the water resistance?
Thank you!
Yannick
tarafından
Yorum Ekle
Yanıtını ekle
Yannick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 296
