Ana içeriğe geç
Repair guides and information for the Nintendo Switch Joy-Con controllers.
167 Soru Tümünü görüntüle
Do you know what component is this one below the battery socket?
Hi, a friend of mine asked me if I can solve his problem with his left joycon, I figured out, comparing it with my functioning joycon, that the problem is a little missing component which with my multimeter seems to be a fuse, do someone knows exactly what component it is and link me a site where I can buy it or if you know how else fix it it would be much appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Angelo,
It looks like a surface-mount resistor, in an “0402” or “0201” package. It’s hard for me to be certain of the package without measuring, but if you have access to a set of calipers you could check the package size yourself. Take a look at this chart and compare to the “imperial” sizes. I would recommend using a multimeter to measure the resistance across the two terminals on your working Joy-Con, and then once you have an estimate of the resistance value, looking on a site like DigiKey for a suitable replacement. A small disclaimer here: the resistance measurement that you take across a resistor when it’s installed in the circuit may not be completely accurate because other components in the circuit can affect the measurement. For something like this, it’s probably a safe assumption that the measurement will put you in the right ballpark.
However, it’s possible (and actually very common) for these resistors to be “jumpers” measuring zero ohms. If that’s the case here, you could simply place a blob of solder on the broken Joy-Con that bridges the two “pads” of the missing component.
Hope this helps,
Chris
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
HI Chris,
thanks for your relply, i don't have caliper right now, but looking at the chart that you linked me I'm pretty sure that it is the "0201", beside that i checked with my multimeter the resistance of the component, since both when i probe the two end of the component and when I make in contact the two probe report the same value should I assume that it is a 0 Ohm resistor? thank you very much for your reply
tarafından
@angix0 If it's measuring close to zero ohms, then it's probably just a "jumper resistor". It's perfectly safe to replace this with a blob of solder that connects the two pads, just be careful to not accidentally bridge to the resistor that is next to them.
tarafından
@chrisgreen it's not so close to zero, in the multimeter that i have right now the lowest resistence is 200 Ohm, so i can measure only value with 1 decimal value, the thing that makes me think that it is a 0 Ohm is the value measeured frome the two probrobes itself that it is always the same as the resistor, should i measure it with a more precise multimeter before bridging it?
tarafından
@angix0 What do the probe leads measure? It's uncommon to see resistors much less than a few ohms in consumer electronics because that requires higher tolerance parts which can get expensive. If you're measuring a few ohms on the leads and the same value on the part in the circuit, I'd say bridging it is safe
tarafından
@chrisgreen yes, it is exactly what happens, thank you a lot. I'll try bridging it.
tarafından
Yorum Ekle
Yanıtını ekle
Angelo Giarratana sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 444
