Ana içeriğe geç
Announced on October 13 and released October 23, Apple's flagship smartphone for 2020 features a 6.1" OLED display, a triple-lens rear camera system with LiDAR, and 5G. Successor to the iPhone 11 Pro.
91 Soru Tümünü görüntüle
Face ID not working
My Screen was damaged and I’ve got a replacement but the ribbon cable off the original earpiece assembly was also damaged and I’ve had to also replace the assembly. As the sensors are paired with the phone once replaced the Face ID is not working. Can the new assembly sensors be programmed to work with the phone to re-enable the Face ID feature?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Unfortunately, the Face ID assembly cannot be repaired under any circumstances except by Apple or their authorized service providers. Face ID data is stored in something called the Secure Enclave in your iPhone. Any attempt to remove it to perform a repair or replacement will result in the secure enclave chip being destroyed or disabled without question, not to mention the data is secured digitally. This is impossible to reprogram yourself; I’m sorry for the disappointing response, but it is the truth. :(
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Hi Marcus, thanks for your response. Do you think it's possible to replace or repair the ribbon which connects to the front earpice assembly?
tarafından
Hey again, not a problem at all! While I can’t say for sure if this would be impossible, I do know that Apple employs tamper-resistant measures in this technology. If your device detects damage or any sort of tampering, there is a good chance Face ID will be disabled even if it is still functional. It may be worth a shot, but I would again advise that the chances are unlikely. I’m sorry for such disappointing answers :(
tarafından
Yorum Ekle
i have same problem on several phones, i believe that there are 2 components that you need to transfer to new flex and it will work, i will update when i receive new flex cables and do the swap - look on youtube - resq
Puan 0
Yorum Ekle
Yanıtını ekle
shaun Henderson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 219
