Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 Soru Tümünü görüntüle
Laptop turns on but blank screen after battery replacement
I have just replaced the battery on my MacBook Pro following the iFixIt guide - all seemed to go well but I’ve turned on my MacBook after charging and the screen is blank, despite making the power on sound.
Does anyone have any suggestions, or know where I can check if the LCD display is connected properly?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @henlomate
It could be your back light circuit not working. Shine a torch onto the screen after the startup chime and see if you see a faded Apple logo on the screen.
If you remove the back cover you should be able to see the LCD connector as per the image below
Make sure you disconnect the battery first before touching the LCD connector to prevent blowing the LCD circuit accidentally!
Have look at the connector itself to see if there is any burn marks, missing pins or blown components nearby.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I would add aim the flashlight though the lids logo as being more effective, you should see your desktop and its icons.
tarafından
Yorum Ekle
Yanıtını ekle
henlomate sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 85
