Please turn camera off and on again
Hii there,
My Lumix TZ60 also display these error messages (System Error (O.I.S) and Please turn camera off and on again)
If you guys solved the problem please help me. Thanks ya
Bu iyi bir soru mu?
Hii there,
Bu iyi bir soru mu?
@zaix most common issue with this “Please turn camera off and on again” is a stuck lens. Once your camera turns on it tries to extend the lens, if it is stuck you get the error message. Check on here for a possible solution
Bu yanıt yardımcı oldu mu?
This solution did not work for my camera. I think I will send it to the service center ASAP. Thank you for your help ya.
@zaix sorry to hear this. Check the prices for a replacement lens and see if you are up for replacing it yourself, if it is not to expensive.
I also had this issue and found another fix. Seems to be the cable ribbon connecting the zoom button to the camera.
I wrote a guide here:
Panasonic Camcorder 'Error Occurred. Please turn unit off , then on again - iFixit Repair Guide
By any chance do you still have this guide?
Please can you share a link to the guide.Thanks
Son 24 Saat: 10
Son 7 gün: 96
Son 30 gün: 357
Her zaman: 18,003
2 Yorum
I would start by removing the battery and turning the camera on/off a few times, then reinstall a fresh battery to see what happens.
bill tarafından
@ruggb This solution did not work for my camera. I think I will send it to the service center ASAP. Thank you for your reply ya.
Zaix tarafından
