Why is my i7 not picking anything up
My roomba goes around like normal but does not vacuum anything up
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hello.
The Ruumba, like all things mechanical needs a bit of maintenance every now and then to keep it working the way it should - for longer. Try checking these maintenance items to see if everything is in check
Bu yanıt yardımcı oldu mu?
In particular, this roomba version depends heavily on the roller due to its terrible fan motor. The rollers are designed to wear away so that they do not wear away your floors and carpet. This means you have to regularly replace them. A good sign that they need to be replaced is the Roomba does a terrible job at picking stuff up
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 48
Her zaman: 364
