Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
20 Soru Tümünü görüntüle
Does the iMac 7,1 (EMC 2133) support 800 MHz RAM?
I’m planning to upgrade my recently restored iMac and would like to know if I could use 800 MHz sticks or if I’m stuck with 667. Also, I’ve heard that this machine can go beyond its 4gb limit to 6gb. Is this true?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You won’t get any better performance as the systems I/O is clocked based. The CAS and RAS timing can be too short causing errors when using too fast RAM. And yes while Apple only lists 4 MB you can go upto 6 MB using one 2 GB SO-DIMM and one 4 GB SO-DIMM and the speeds need to match!
I would stick to the spec’ed RAM.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Ok, thanks. I'll keep that in mind.
tarafından
Yorum Ekle
Yanıtını ekle
Zachary Rushworth sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 115
